Brent CXC Pottery Wheel
Revision as of 06:53, 9 April 2025 by Reallyrosemary (talk | contribs) (Added a comment on the use-case)
The Brent Pottery Wheel is a machine used to shape clay, and the studio has 5 near the back of the ceramics room.
Brent Pottery Wheel - Model CXC
Pottery Wheels
Asset Tag # Simple ID # Make Model Serial
000259 1 Brent CXC 22227M 114413
000260 2 Brent CXC 22227M 114410
000261 3 Brent CXC 22227M 114408
000262 4 Brent CXC 22227M 114027
000263 5 Brent CXC 22227M 114019
Ceramics Studio Introduction (CSI) is required to use this tool.
Etiquette (if relevant)
Example:
The pottery wheel is a versatile tool used to shape and form clay by rotating on a flat surface, allowing the potter to manipulate the clay into symmetrical shapes, such as bowls, plates, vases, or mugs.
Tool Use
The ceramic studio is a shared space therefore cleaning after use is expected.
  • Clean up any clay around the tool.
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
SIG Information (if relevant)
Common Projects
