Brent CXC Pottery Wheel
Members must complete the Class before using this tool
The Brent Pottery Wheel is a machine used to shape clay, and the studio has 5 near the back of the ceramics room.
| Asset Tag # | Simple ID # | Make | Model | Serial |
| 000259 | 1 | Brent CXC | 22227M | 114413 |
| 000260 | 2 | Brent CXC | 22227M | 114410 |
| 000261 | 3 | Brent CXC | 22227M | 114408 |
| 000262 | 4 | Brent CXC | 22227M | 114027 |
| 000263 | 5 | Brent CXC | 22227M | 114019 |
Ceramics Studio Introduction (CSI) is required to use this tool.
Etiquette (if relevant)
Example:
The pottery wheel is a versatile tool used to shape and form clay by rotating on a flat surface, allowing the potter to manipulate the clay into symmetrical shapes, such as bowls, plates, vases, or mugs.
To use a pottery wheel, please reserve one at Skedda
Tool Use
The ceramic studio is a shared space therefore cleaning after use is expected.
- Clean up any clay around the tool.
- What to clean
- How to clean
- Where to dispose of waste
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
Common Projects
