Baldor 333B Buffer Polisher
Revision as of 22:15, 14 December 2025 by Aneel (talk | contribs)
The Baldor 333B buffer-polisher is used for buffing and/or polishing metal parts.
Polishing guidelines
Before using the polishing wheel, please make sure you have sanded your piece with a high grit sandpaper. 400 is the minimum, ideally 600 or higher.
To prevent misuse and high wear, the polishing wheel has been removed from the polisher. Please contact any of the stewards for instruction on how to get it.
