Pausing prints in Octoprint
Revision as of 02:49, 29 January 2026 by Aneel (talk | contribs)
State of the Printers
Challenge
🛑 PrusaSlicer's default pause does not work correctly with Octoprint on our MK3S+ printers!!!
TL;DR
   G1 X0. Y210.           ; get the hotend out of the way
   M104 S0                ; turn off extruder heater, so the nozzle doesn't dribble
   M300                   ; make a horrible noise (optional)
   M0                     ; pause
   M104 S{temperature[0]} ; set extruder temp
   M109 S{temperature[0]} ; wait for extruder to reach temp
This should work whether the job is started from Octoprint or from the SD card.
Gory Details
The default pause gcode is ```M601```
