Pausing prints in Octoprint
Revision as of 19:33, 29 January 2026 by Aneel (talk | contribs) (→‎TL;DR)
State of the Printers
Challenge
Add Pause in PrusaSlicer
We would like to be able to pause prints programmatically, so that we can do things like insert magnets or windows, or measure tolerances. PrusaSlicer has built in functionality for this. You can right click on the layer control in the sliced view and insert a pause.
🛑 PrusaSlicer's default pause does not work correctly with Octoprint on our MK3S+ printers!!!
TL;DR
Custom Pause in PrusaSlicer
G1 X0. Y210.           ; get the hotend out of the way
M104 S0                ; turn off extruder heater, so the nozzle doesn't dribble
M107                   ; turn off print fan
M300                   ; make a horrible noise to get the user's attention (optional)
M601                   ; tell printer to pause
@pause                 ; tell Octoprint to pause
M602                   ; resume
M109 S{temperature[0]} ; set extruder temp and wait for extruder to warm up
M106                   ; turn on print fan
M117 Resumed           ; write message on the screen
Now, when you This should work whether the job is started from Octoprint or from the SD card. You should be able to resume either from the control screen on the printer or from Octoprint.
Gory Details
The default pause gcode in PrusaSlicer is M601. When issued from a SD card, this works properly: It parks the hotend out of the way, turns off the extruder heater so filament doesn't dribble out, and shows "Print Paused" on the screen. When you resume the print, it turns the extruder heater back on, waits for it to get to temperature, and then continues. When issued from the serial interface the printer assumes that the serial controller will be responsible for all of the resumption commands. Octoprint doesn't assume this! It doesn't turn the extruder heater back on, which ruins the print.
Okay. Can we have Octoprint issue the M602 "Resume Print" gcode. Could our pause gcode just be...
   M601
   M602
This doesn't work for two reasons. First, Octoprint doesn't treat M601 as a pause, so it just immediately continues to M602. We could maybe address this by adding a @pause Octoprint directive between those two commands, but... Second, in the firmware that we're running, M601 doesn't save the information it needs to properly resume on M602 if it thinks it's not the host. This would probably work after firmware version 3.14, but we're stuck on an earlier version. So in the suggested gcode above, we do the resumption ourselves.
When Octoprint encounters the M0, it suppresses it and just stops sending commands to the printer. This means that the printer doesn't know it's been paused and you have to resume from Octoprint, not from the display on the printer. We might be able to send M601 then @pause...
