CR-10S
Revision as of 03:55, 28 June 2022 by Pearlgreymusic (talk | contribs) (Pearlgreymusic moved page Creality CR-10S to CR-10S over redirect)
The Creality CR-10S is a 3D printer at the space. Because it has a Bowden extruder setup, it is NOT recommended to use flexible filaments (such as TPU) with the CR-10. This CR-10S is modified, so it may have specifications different from the stock specifications outlined in the manual. List of known modifications TBA.
Status | Active |
Manufacturer | Creality |
Model | CR-10S |
Nozzle Size | 0.4mm |
Nozzle Type | Brass(?) |
Nozzle Count | 1 |
Filament Size | 1.75mm |
Print Volume | 300 x 300 x 400mm |
Max Bed Temperature | 90(?)C |
Max Nozzle Temperature | 230(?)C |
Max Print Speed | 60(?)mm/s |
Extruder Type | Bowden |
Manual | Unknown |
Control Interface | Octoprint |
Network Address | http://192.168.0.175:5002 |
