The printers are controllable over Octoprint, which you can use the web browser or an app to connect to while on the ASMBLY network. You cannot access these machines from home. Tasks such as preheating and filament changes can be done via the built-in panel on the front bottom of the printer.
Apollo
| Status |
Active
| Video Feed |
Unknown
| Manufacturer |
Prusa
| Model |
i3 MK3S+
| Nozzle Size |
0.4mm
| Nozzle Type |
Hardened Steel
| Nozzle Count |
1
| Filament Size |
1.75mm
| Print Volume |
250 x 210 x 210mm
| Max Bed Temperature |
122C
| Max Nozzle Temperature |
295C
| Max Print Speed |
100mm/s
| Extruder Type |
Direct
| Manual |
Unknown
| Control Interface |
Octoprint, Device Screen & Buttons
| Network Address |
http://apollo-printer.local/
Hermes
| Status |
Active
| Video Feed |
Unknown
| Manufacturer |
Prusa
| Model |
i3 MK3S+
| Nozzle Size |
0.4mm
| Nozzle Type |
Hardened Steel
| Nozzle Count |
1
| Filament Size |
1.75mm
| Print Volume |
250 x 210 x 210mm
122C
295C
| Max Print Speed |
100mm/s
| Extruder Type |
Direct
| Manual |
Unknown
| Control Interface |
| Network Address |
http://hermes-printer.local/
Sunwukong
| Status |
Active
| Video Feed |
Unknown
| Manufacturer |
Prusa
| Model |
i3 MK3S+
| Nozzle Size |
0.4mm
| Nozzle Type |
Hardened Steel
| Nozzle Count |
1
| Filament Size |
1.75mm
| Print Volume |
250 x 210 x 210mm
122C
295C
| Max Print Speed |
100mm/s
| Extruder Type |
Direct
| Manual |
Unknown
| Control Interface |
| Network Address |
http://sunwukong-printer.local/
