Prusa MK3S+
Revision as of 03:09, 14 February 2024 by Pearlgreymusic (talk | contribs)
The printers are controllable over Octoprint, which you can use the web browser or an app to connect to while on the ASMBLY network. You cannot access these machines from home. Tasks such as preheating and filament changes can be done via the built-in panel on the front bottom of the printer. The Octoprint configuration is the standard OctoPi installation, consisting of the Raspberry Pi 3 or 4 being attached to the back of the printer frame, connected via USB to the printer and via Ethernet to the ASMBLY network (WiFi connection from the Pi to the network is currently unstable), with the OctoPi 1.0.0 (build 2023.10.09.151442) stable image installed on the Pi. In an attempt to keep the printers as easily serviced and maintained, we are trying to keep the installation as standard as possible. More documentation about OctoPi can be found here. Files for printing replacement Pi 3B and Pi 4B cases can be found at the page bottom.
Apollo
Status Active
Manufacturer Prusa
Model i3 MK3S+
Nozzle Size 0.4mm
Nozzle Type Hardened Steel
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 122C
Max Nozzle Temperature 295C
Max Print Speed 100mm/s
Extruder Type Direct
Manual Unknown
Hermes
Status Active
Manufacturer Prusa
Model i3 MK3S+
Nozzle Size 0.4mm
Nozzle Count 1
Manual Unknown
Sunwukong
Status Active
Manufacturer Prusa
Model i3 MK3S+
Nozzle Size 0.4mm
Nozzle Count 1
Manual Unknown
