Laguna TFlux 5 Dust Collector
| West Bend Edge Belt Sander | 010010 | B | |
| Bosch Miter Saw | 000010 | A | |
| Grizzly G0569 Bandsaw | 010000 | B | |
| Powermatic Large Belt Sander | 010001 | B | |
