Tormach PCNC 1100 Overhaul
- 1.5hp R8 Spindle
- Table Size: 34" x 9.5"
- Table Slots: 3 Slots 5/8"
Maximum Sizes and Weights
- Size: 18" x 9.5" x 16.25" (X,Y,Z)
- Weight: 500 lbs
Distilled water can be found underneath the tool. Coolant mix is in a bucket in the tool cabinet under the loft.
Feeds and Speeds
Setup
There is a rotary power switch inside the enclosure on the right side of the machine. There is a start button and an emergency stop button (E-stop) above the enclosure doors. The console is on a swinging arm on the right side of the enclosure.
Basic Operation
Turning on the Machine
- Check the oiler
WHICH IS SOMEWHERE
.CONTACT A STEWARD IF THE OIL LEVEL IS LOW?
- Check the coolant reservoir. To see the level, look
WHERE THE COOLANT LEVEL IS CHECKED
. Top up, if necessary- Coolant should be made with
X PARTS DISTILLED WATER AND Y PARTS NAME OF COOLANT MIXTURE
Transferring Files
- There is a USB Hub that can read FAT-formatted USB drives. Use the Files button in the console
HOW???
Preparing Tools
- There is a tool tightening fixture mounted on the cabinet top.
DESCRIPTION OF HOW TO USE
Inserting & Removing Tools
- To insert:
- Open the spindle cover door
- To remove:
Work Holding
Referencing
- Click Ref X and Ref Y
Probing
- Use a wet/dry vac to clean up chips
Software
Fusion is installed on the computers in the Textiles room. Autodesk offers free subscriptions for educational users. Autodesk also offers a personal subscription for non-commercial use, however **be aware that it doesn't support post processing NC paths with tool changes**. Transferring projects from a personal account to another account is surprisingly difficult.
Tooling
IS IT ALLOWED/ENCOURAGED TO USE THE TOOLING FROM THE MANUAL MILL IN THE CABINET NEXT TO THE SURFACING WHEEL?
SIG Information
- ProvenCut as a reference for feeds & speeds
- Look at the tool paths on the display. Do they look correct?
