Tormach PCNC 1100 Overhaul
- 1.5hp R8 Spindle
- Table Size: 34" x 9.5"
- Table Slots: 3 Slots 5/8"
Maximum Sizes and Weights
- Size: 18" x 9.5" x 16.25" (X,Y,Z)
- Weight: 500 lbs
Distilled water can be found underneath the tool. Coolant mix is in a bucket in the tool cabinet under the loft.
Feeds and Speeds
Setup
Basic Operation
Turning on the Machine
- Check the oiler, which is on the lower left side of the machine. Contact a steward if the oil level is low
- Check the coolant pressure. Open the valve fully and click the Coolant button on the console. The stream should have enough pressure to remain straight over several inches.
- Coolant should be made with 5-10% concentrate, and the rest distilled water
Transferring Files
- There is a USB Hub that can read FAT-formatted USB drives. Use the Files button in the console
- Browse the Asmbly wifi network for
tormachpcnc
and mount thegcode
share as a guest, or connect tosmb://tormachpcnc
(Mac) or\\tormachpcnc
(Windows)
Preparing Tools
- There is a tool tightening fixture mounted on the cabinet top. To tighten, insert the collet in the left side of the bushing and tighten with the wrench. To loosen, insert the collet in the right side of the bushing and loosen with the wrench
Inserting & Removing Tools
- To insert:
- Open the spindle cover door
- To remove:
Work Holding
Referencing
- Click Ref X and Ref Y
Probing
- Use the appropriate shopvac for the material you machined
- Don't forget to move the table of the machine to clean the accordion ways covers on both sides.
Software
Fusion is installed on the computers in the Textiles room. Autodesk offers free subscriptions for educational users. Autodesk also offers a personal subscription for non-commercial use, however **be aware that it doesn't support post processing NC paths with tool changes**. Transferring projects from a personal account to another account is surprisingly difficult.
Tooling
IS IT ALLOWED/ENCOURAGED TO USE THE TOOLING FROM THE MANUAL MILL IN THE CABINET NEXT TO THE SURFACING WHEEL?
SIG Information
- ProvenCut is a reference for feeds & speeds
- Look at the tool paths on the display. Do they look correct? Does the position of the tool onscreen match the physical position of the tool? Make sure the right tool number is selected before comparing. Use the arrow keys to reposition the tool. Are the coordinates what you expect?
