Tethys
Revision as of 18:25, 29 August 2024 by YellowEng (talk | contribs) (Created page with "Asmbly owns the ELEGOO Saturn printer SLA printers. We also own the ELEGOO Mars 2P, a cure post-processing equipment. Only resin purchased from Asmbly may be used in these pr...")
Unnamed SLA Printer
Example Example
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
