Laguna TFlux 5 Dust Collector
- Users Manual
- iVac Pro System Guide
- iVac Blast Gate User Manual
iVac System Addresses
Usage Notes
- If desired, you can turn on the dust collector before you start using any tools.
- If you do rely on the automatic control to turn on the dust collector, please give it a 10 seconds or so to turn on and spin up.
- When changing the dust bin, please make sure other users are aware and do not use any tools, so the dust collector is not turned on without the bin.
| Mode | LED |
| Standby | LED flases every 4 seconds |
| On | LED on |
| 8 minute off timer | LED flashes 2x or 5x per second |
Implementation
The daisy chain setup is plugged in high above the router table.
