Tethys
| Manufacturer | Elegoo |
| Model | Elegoo Saturn 3 Ultra |
| LCD | 10-inch 12K Mono LCD |
| System | EL3D-4.0 |
| Slicer Software | CHITUBOX & Voxeldance Tango |
| Technology | MSLA Stereolithography |
| Printing Speed | Maximum 150mm/h |
| Z Axis Accuracy | 0.01mm |
| XY Resolution | 19 x 24μm (11520 x 5120) |
| Build Volume | 218.88mm(L) * 122.88mm(W) * 260mm(H) |
| Light Source | COB + Refractive Light Source (Wavelength 405 nm) |
| Weight | 16.2kg |
| Operation | 4.0-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz 24V 7.5A |
| Printer Dimensions | 305.9mm(L) * 273mm(W) * 562.5mm(H)
- Keep the 3D printer and its accessories out of reach of children.
Resin Safety
- Avoid breathing vapors.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
- Go to "Settings" and select ELEGOO Saturn 3 Ultra as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
Post-Processing
If parts fell off of the build platform and are hanging around in the tank, the easiest thing to do is to go to the Tools menu and run Tank Clean. This will take less than a minute, and will result in a sheet being printed that covers the whole of the LCD screen area at the bottom of the tank, hopefully adhering to any fallen bits. You can use a spatula to carefully fish the sheet out of the tank.
Common Projects
