Elegoo Saturn 3 Ultra
Unnamed SLA Printer
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
Resin Safety
  • Avoid breathing vapors.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
Post-Processing
Resin Tank Cleanup
3D Printers Space Team
Common Projects
