Brent CXC Pottery Wheel
Members must complete the Class before using this tool
| Asset Tag # | Simple ID # | Make | Model | Serial |
| 000259 | 1 | Brent CXC | 22227M | 114413 |
| 000260 | 2 | Brent CXC | 22227M | 114410 |
| 000261 | 3 | Brent CXC | 22227M | 114408 |
| 000262 | 4 | Brent CXC | 22227M | 114027 |
| 000263 | 5 | Brent CXC | 22227M | 114019 |
<INSERT PHOTO OF EQUIPMENT>
Ceramics Studio Introduction (CSI) is required to use this tool.
Etiquette (if relevant)
Example:
Tool Use
- What to clean
- How to clean
- Where to dispose of waste
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
Common Projects
