Module:Navbar/configuration
< Module:Navbar
Revision as of 05:39, 13 November 2021 by w>Izno (well, since I edited the other one...)
Documentation for this module may be created at Module:Navbar/configuration/doc
return { ['templatestyles'] = 'Module:Navbar/styles.css', ['box_text'] = 'This box: ', -- default text box when not plain or mini ['title_namespace'] = 'Template', -- namespace to default to for title ['invalid_title'] = 'Invalid title ', ['classes'] = { -- set a line to nil if you don't want it ['navbar'] = 'navbar', ['plainlinks'] = 'plainlinks', -- plainlinks ['horizontal_list'] = 'hlist', -- horizontal list class ['mini'] = 'navbar-mini', -- class indicating small links in the navbar ['this_box'] = 'navbar-boxtext', ['brackets'] = 'navbar-brackets', -- 'collapsible' is the key for a class to indicate the navbar is -- setting up the collapsible element in addition to the normal -- navbar. ['collapsible'] = 'navbar-collapse', ['collapsible_title_mini'] = 'navbar-ct-mini', ['collapsible_title_full'] = 'navbar-ct-full' } }
