Laguna TFlux 5 Dust Collector
(Redirected from 000050)
iVac System Addresses
iVac Tool Pro/Blast Gate ID Codes
Machine ID Code Individual Power or USB Hub System Address
Powermatic Combo Belt/Disc Sander 000001 A
iVac Tool Switch (Daisy Chain Address C to A) 000010 A
Laguna Jointer 000011 A
Table Saw 2 000100 A
Table Saw 1 ICS51230 010111 C
Powermatic Planer 000101 A
Router Table 000110 A
Supermax Drum Sander 000111 A
IVac DC Switch (Daisy Chain Address C to A) C
Grizzly G0569 Bandsaw 010000 C
Powermatic Large Belt Sander 010001 C
West Bend Edge Belt Sander 010010 C
Dust Collector Remote Control C
Grizzly G0817 - A01 Blast Gate D
Grizzly G0817 (1) 110010 Individual D
Grizzly G0817 (2) 110100 Individual D
Usage Notes
  • The dust collector will automatically turn on and off. It is still the users responsibility to make sure the dust collector is on before using a woodshop tool.
  • When turning on a tool when the dust collector is off, please give it a 10 seconds or so for the dust collector to spin up before using the tool.
  • When changing the dust bin:
    • Please make sure other users are aware and do not use any tools
    • Turn the switch on the yellow box on the dust collector to "off" instead of "auto".
    • Return the mode to "auto" after the bin has been emptied.
  • The control is programmed to remain on for 8 minutes after all tools are shut off. The prevents a lot of starts and stops.
iVac MSC LED Guide
Mode LED
Standby LED flases every 4 seconds
On LED on
8 minute off timer LED flashes 2x or 5x per second
Implementation
The daisy chain setup is plugged in high above the router table.
Troubleshotting Steps for Blast Gates
  • Verify tool sensor and blast gate are set to "AUTO"
  • Verify tool sensor has red light when tool is powered on
    • If not, verify tool sensor is plugged in
      • Check outlet is working
      • Check USB port is working
      • Swap USB power supplies
    • If power is good, try adjusting sensitivity setting, verify dip switch settings are correct
  • Check if blast gate is opening:
    • If the green area is showing, the gate is open
    • Disconnect hose, and verify suction is good
      • Check for blockages in the hose
  • If tool sensor is working, and blast gate is not opening:
    • Try changing the blast gate to ON/CLOSED and verify if the gate is opening/closing
      • Is the gate making any noise? If so, it may be a mechanical issue with the gate itself
    • If not making any noise, check if outlet has power
    • If outlet is working, verify gate power supply is working
      • check for voltage
      • swap power supply with spare from the stewards closet
Troubleshooting Automatic Control
  • If a tool is not triggering the dust collector, verify the tool sensor is working correctly.
    • verify iVac MSC on dust collector is set to "auto"
    • verify tool sensor is set to "auto"
    • verify tool sensor LED is lit when the tool is turned on
    • If the tool is on system address C, verify iVac switch above router table is activated when the tool is turned on
      • There should be a blue led you can see when it is activated
      • This iVac switch should be set to auto
      • The tool sensor it is connected to should be set to "off-ext"
      • Try unplugging both the tool sensor and switch, and plug back in.
    • Try turning all tools off, turn automatic control to off, then back to auto.
  • If the dust collector is not turning off
    • Check iVac MSC LED, if light steadily, it thinks a tool is on
    • Verify nothing sneaky a turned on, examples:
      • South Bend sander master power enabled, but belt not running
      • Drum Sander belt running
      • A tool sensor set to "on" instead of "auto"
    • Check iVac MSC LED, if blinking at 4x per second, DC should shut off within 8 minutes
