3D Printer Cameras
This page is intended for Stewards. To see the camera video, you should visit the Wiki page for the appropriate printer.
We are installing some old Amcrest IP cameras (IP5M-T1179EW-AI-V3) to allow remote monitoring of the 3D printers.
The IP cameras have static IPs on the Asmbly local network, eg. 192.168.0.244
We are making the RTSP stream (TCP and UDP port 554) available to the outside world at shop.asmbly.org:3NNN with NNN matching the IP of the camera, for example you should be able to view a stream using VLC by specifying rtsp://viewer:PASSWORD@shop.asmbly.org:3NNN
Ports
3078 Sun Wukong
3162 Hermes
3240 XL
3244 Apollo
Because web browsers don't natively support RTSP streams, we have set up an installation of Restreamer on an AWS EC2 instance that pulls the RTSP streams and makes them available in a web player.
To set up Restreamer we did:
ssh ec2-user@ec2-18-117-124-192.us-east-2.compute.amazonaws.com
sudo yum install -y docker
sudo service docker start
sudo usermod -a -G docker ec2-user
docker run -d --restart=always  \
  --name restreamer \
  -v /home/ec2-user/restreamer/config:/core/config \
  -v /home/ec2-user/restreamer/data:/core/data \
  -p 80:8080 -p 443:8181 \
  datarhei/restreamer:latest
Then configured the streams using the web interface. Also set up LetsEncrypt in the Settings.
To view the stream, you can hit http://restreamer.asmbly.org:8080/cd831f90-1b43-494b-92e2-1407d2779432.html with the appropriate UUID for the camera you want.
Also added https://www.mediawiki.org/wiki/Extension:IframeTag to our wiki, with just restreamer.asmbly.org allowed.
Todo
  • Mount a camera for each Prusa printer
  • Hook up POE switch and run cables nicely
  • Figure out how to embed the restreamer video in wiki pages
  • Figure out what to do about the Bambu. Can we restream the built in camera? Link it directly?
  • Figure out how to overlay status/time remaining data from the printers on the video
    • Octoprint -> Home Assistant -> MQTT -> Amcrest API to set the watermark???
