Dione
Asmbly owns the ELEGOO Saturn 4 Ultra SLA printer.
[[File:|alt=Photo of Elegoo Saturn 4 Ultra Resin printer|center|frameless]]
| Manufacturer | Elegoo |
| Model | Elegoo Saturn 4 Ultra |
| LCD | 10-inch 12K Mono LCD |
| System | EL3D-4.0 |
| Slicer Software | ChituBox & Autodesk Fusion |
| Technology | MSLA Stereolithography |
| Printing Speed | Maximum 150mm/h |
| Z Axis Accuracy | 0.02mm |
| XY Resolution | 19 x 24μm (11520 x 5120) |
| Build Volume | 218.88mm(L) * 122.88mm(W) * 220mm(H) |
| Light Source | COB Light Source + Fresnel Collimating Lens (Wavelength 405 nm) |
| Weight | 19.3kg |
| Operation | 4.0-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz 24V 6A |
| Printer Dimensions | 327.4mm(L) * 329.2mm(W) * 548mm(H) |
- Keep the 3D printer and its accessories out of reach of children.
Booking Policy
The resin printers do not have a daily limit on booking time, but the time spent with the printers should include not only the print time, but also the additional time needed for pre-print and post-print tasks. Please incorporate this extra time when booking the printers. For example, if you start a resin print, but won't be back to remove it from the build plate until the next day, book the printer until the next day.
Because 3D Prints involve a lot of time when you don't need to be present, the policies are slightly different from the general booking policies.
- Time booked for 3D printing in Skedda does not count against your weekly usage hours, but time on the XL is limited to 48 hours per week. If you want to print a large object that will take longer, book the first 48 hours and email 3dprinters@asmbly.org to request more time. If it's available, we'll try to book it for you.
- It is fine for a print to continue while Asmbly is closed.
- You may book up to two 3D printers at a time.
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened.
Resin Safety
- Avoid breathing vapors.
The Saturn 4 Ultra is an SLA printer that combines fast print speeds with top-notch quality. It includes a USB-attachable carbon filter to reduce odors and allows file uploads via USB or Wi-Fi for easy connectivity. Its high-resolution output makes it perfect for detailed, precision projects.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
- Go to "Settings" and select ELEGOO Saturn 4 Ultra as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
- Note from a Steward: Please be aware that at least some versions of CHITUBOX will attempt to auto correct an infrequent issue on build plate leveling by including in the slicing data a command to over shoot the the set zero that can lead to print fails by print over compression. After leveling, run a test print and then manually adjust the z height by the .1mm it is off by the calipers. As of 4/11/2025 the proper z hieght post leveling needs to be set at .9 mm above level sheet.
Post-Processing
If your print fails, particularly if some parts of the print don't adhere to the bed, it's likely you'll need to do a Resin Tank Cleanup. Please try to leave the tank debris-free for the next user.
Common Projects
