EinScan-SE 3D Scanner
The 3D Scanner can be found on the table to the right of the Filament Printer enclosure.
The 3D Scanner can make 3D models of physical objects.
We don't currently require Skedda bookings to use the 3D Scanner.
Any, but reflective, transparent, or deep black materials may not work well without 3D Scan Spray or Talc powder.
| Scan Mode | Fixed Scan with Turntable | Fixed Scan without Turntable |
| Mode of Alignment | Feature; Manual; Turntable | Feature; Manual |
| Single Shot Accuracy | ≤0.1 mm | |
| Minimum Scan Volume | 30 × 30 × 30 mm | |
| Maximum Scan Volume | 200×200×200 mm | 700×700×700 mm |
| Single Scan Range | 200×150 mm | |
| Scan Speed | Single Shot<1 s
Turntable<45 s | |
| Point Distance | 0.17 mm ~ 0.2 mm | |
| Texture | Yes | |
| File Format | OBJ, STL, ASC, PLY, 3MF | |
| Camera Resolution | 1.3 Mega Pixels | |
| Light Source | White LED | |
| Working Distance | 290 ~ 480 mm | |
| Computer Requirements (Required) | USB:1 ×USB 2.0 or 3.0; OS: Win7, 8 or 10 (64 bit); Graphic Card: Nvidia series; Graphic memory: >1G; CPU: Dual-core i5 or higher; Memory: >8G | |
| Computer Requirements (Recommended) | Graphics card: NVIDIA GTX660 or higher; Graphics memory: >2 G; CPU: Dual Core I5 or higher; Memory: >16 G | |
| Scanner Body Weight | 2.5 kg | |
| Dimension | 570×210×210 mm | |
| Power Supply | 40 w | |
| Input Voltage | DC:12 v, 3.33 A | |
| Calibration Board | Standard | |
| Turntable | Standard | |
| Load Capacity of Turntable | 5 kg | |
Asmbly has a laptop dedicated to the use of the scanner. The windows password is 12341.
Asmbly does not provide these, but you may find them useful.
- Mounting putty (blue tack) will help hold your item in certain orientations.
- 3D scan spray/Talc powder will help the 3D scanner to capture highly reflective, transparent and deep black surface.
You will probably want to move the scanner and laptop to a table that provides more space to work.
Connect Cables
Plug all cables into both the scanner and the laptop.
Power On
Turn on the scanner by pressing the power button for at least 2 seconds.
Launch Software
Open the EXScan software.
Calibrate
For optimal results and accuracy, calibrate the scanner before starting any scans. Follow the on-screen instructions to calibrate using the calibration plate (a square board with dots).
Optional: When scanning models with color texture, perform a white balance calibration using a white piece of paper.
Scan and Output
Once calibration is complete, position your model at the center of the turntable, then click on "New Project."
Select a save directory, enter a project name, and choose either "Texture Scan" or "Non-texture Scan."
Select the appropriate brightness to minimize red areas in the live camera feed. The default turntable steps are set to 8, which works well for most items, but feel free to adjust if necessary. Then, click Start Scan on the right to begin the scanning process.
Once the scan completes after the 8 turns, click on Apply Edit to complete the current scan.
Adjust the orientation of the item to capture any missing areas from the first scan, and repeat the process as needed. Once you have captured sufficient detail around the item, click Global Optimization to complete the scan.
The software will align all of the scan. If the result looks good, hit Confirm.
Once the scan has been aligned, turn the point cloud into mesh by clicking on Mesh Model.
Select type of mesh:
Then export your 3D model to the appropriate file format:
Please put the 3D scanner and the laptop back on the table when you're done and make sure all of the cables are there. Plug in the laptop's power cable.
