Elegoo Mars 2 Pro
Asmbly owned a ELEGOO Mars 2P SLA printer.
Retired — no longer available at Asmbly. Replacement: Dione.
| Manufacturer | Elegoo |
| Model | Elegoo Mars 2 Pro |
| Technology | UV Photocuring |
| Printing Speed | 30 - 50mm/h |
| Z Axis Accuracy | 0.00125mm |
| XY Resolution | 0.05mm (1620 * 2560) |
| Build Volume | 129mm(L) * 80mm(W) * 160mm(H) |
| Light Source | UV Integrated Light (Wavelength 405 nm) |
| Connectivity | USB Interface |
| Weight | 6.2kg |
| Operation | 3.5-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz |
| Printer Dimensions | 20cm(L) * 20cm(W) * 41cm(H) |
- Keep the Mars 2 Pro 3D Printer and its accessories out of the reach of children.
Resin Safety
- Avoid breathing vapors.
The Mars 2 Pro is an SLA printer known for its high-resolution output and consistent print quality. It supports file uploads via USB, and its impressive resolution makes it ideal for detailed and precision projects.
You may purchase resin here.
Available Resin Materials
Chitu Box Slicer Setup
- Go to "Settings" and select ELEGOO MARS 2 PRO as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Bottom Layer Count: 3-6 layers
Exposure Time: 1.5-3s (Set according to the layer height and complexity of the model. Thicker layers require longer exposure times, resulting in lengthier prints).
Bottom Exposure Time: 20-40s (Longer exposure times create a stickier bottom on the build plate).
Light-off Delay/Bottom Light-off Delay: 7s/8s
Bottom Lift Distance: 5mm
Lifting Distance: 3-5mm
Bottom Lift Speed: 90mm/min
Lifting Speed: 100mm/min
Retract Speed: 150mm/min
Leveling the Bed
Post-Processing
