Jet Oscillating Spindle Sander Model JOSS-S
The Jet JOSS-S is a heavy-duty, professional-grade floor-standing oscillating spindle sander designed for precision curve, contour, and edge sanding in woodworking applications. Powered by a robust 1-horsepower motor, it is engineered to handle continuous shop use while maintaining high stability and minimal vibration.
Key Technical Features
- Advanced Oscillation: Features a 1-1/2-inch spindle stroke length operating at 30 oscillations per minute, which shifts the sanding sleeve vertically to prevent heat buildup, reduce wood burning, and prolong abrasive life.
- Dual-Direction Tilting Table: Equipped with a precision-ground, heavy-duty cast iron table that tilts up to 45° forward and 15° backward, supported by a 90° quick-index stop for fast resets.
- Integrated Spindle Storage: Built-in shelving beneath the table keeps all 10 included spindle assemblies (ranging from 1/4-inch to 4-inch diameters) and matching table inserts neatly organized and easily accessible.
- Tool-Less Changes: Utilizes an integrated spindle lock system that allows woodworkers to swap sanding drums rapidly without requiring external wrenches.
- Durable Drive System: Built with an oil-bath worm gear mechanism that ensures smooth operation and a long operational lifespan under heavy workloads.
- Optimized Dust Control: Features a built-in 4-inch dust port coupled with an under-table shroud for highly efficient sawdust extraction.
