Manual Milling Class
This class focuses on using the Rong-Fu 45 Vertical Mill as well as a lot of other tools (DO-All Bandsaw, Sandblaster, Belt Sander, and grinder). It is a required prerequisite for the Tormach class. Each student will leave the class with a key chain made in the class.
Please review the how to indicate a vise and the climb vs conventional milling video located at the link below before the class.
http://tomstechniques.com/instructional-videos/milling/
Syllabus
  • Safety
  • Parts of the Mill
  • How to indicate a vise
  • How to calculate proper machine RPM
  • Difference between climb and conventional milling
  • How to square a part
  • How to layout a semi precise part with Dykem fluid and calipers
  • How to center drill, drill, and counter bore
  • How to mill a pocket
  • How to use the Do-All Bandsaw
  • How to use the sandblaster
  • How to make a leather insert on the Laser
This is an active class at Asmbly. If you can't find an upcoming session in the Class Schedule, please use the "Request this Class" form under the class description to let us know. We will schedule a session once we have enough interest.
