Laguna Swift Vacuum CNC
Revision as of 21:25, 15 October 2024 by Sid (talk | contribs)
Members must complete the Intro to CNC Routers Class before using this tool
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6.
  6. Empty DC - both the separator and the bag
  7. Take large scraps to dumpster
