Tormach PCNC 1100 Overhaul
Revision as of 23:16, 11 July 2024 by Aneel (talk | contribs)
🛑 This page is a work in progress for the Wiki Overhaul project. Please visit Tormach PCNC 1100 for authoritative information.
Tormach PCNC 1100 Series 3
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
Maximum Sizes and Weights
  • Weight: 500 lbs
Feeds and Speeds
Setup
Basic Operation
Turning on the Machine
  • Check the oiler, which is on the lower left side of the machine. Contact a steward if the oil level is low
  • Oil reservoir level
  • Chck the coolant pressure. Open the valve fully and click the COOLANT button on the console. The stream should have enough pressure to remain straight over several inches. If you need to add coolant, mix 5-10% concentrate and the rest distilled water. The concentrate is a brown liquid that should be in the tall cabinet in the machining area. Give it a good shake to mix it before adding it to the reservoir. You can pour the coolant into the drain in the enclosure.
  • Good coolant flow
  • Insufficient flow
  • Coolant concentrate
  • Mixing the coolant
Transferring Files
  • There is a USB Hub that can read FAT-formatted USB drives. Use the Files button in the console
Preparing Tools
    • There is a tool tightening fixture mounted on the cabinet top. To tighten, insert the collet in the left side of the bushing and tighten with the wrench. To loosen, insert the collet in the right side of the bushing and loosen with the wrench
  • A tool in an ER20 collet on the left side of the fixture with a wrench
Inserting & Removing Tools
  • To insert:
    • Open the spindle cover door
  • To remove:
Work Holding
Referencing
  • Click Ref X and Ref Y
Probing
Software
Fusion is installed on the computers in the Textiles room. Autodesk offers free subscriptions for educational users. Autodesk also offers a personal subscription for non-commercial use, however **be aware that it doesn't support post processing NC paths with tool changes**. Transferring projects from a personal account to another account is surprisingly difficult.
Tooling
  • Tooling used with the manual mills (in the cabinet across from the Rong Fu RF-45 Mill) can be used with the Tormach, but is not high quality and is considered a consumable
Machining Shop Space Team
SIG Information
Common Projects
