Precision Matthews 1054TV Mill
Revision as of 22:04, 25 July 2024 by Mgmoore (talk | contribs)
The Precision Matthews 1054-TV is a Bridgeport-style knee mill featuring 3-axis DRO, 3-axis power feed, and a power drawbar. It's used for accurately machining/drilling metals and other materials.
The power head is 3hp variable-speed with back gear for a total speed range of 70-4200rpm. Speed control is mechanical, so reducing speed increases torque.
ClassWarningIcon.png Members must complete the Manual Milling Class before using this tool
Members who took the Manual Mill Class before the Precision Matthews Mill came online are required to familiarize themselves with the differences between this mill and the Rong Fu Mill by reading this document. A separate class is not required, but users are responsible for understanding the material presented there.
720px
4 Back Gear Selector
5 Spindle Brake
6 Spindle Speed Control
7 Motor Switch
8 Quill Auto Feed On/Off
9 Quill Fine Feed Handwheel
10 Quill Auto Feed Rate Selector
11 Quill Auto Feed Direction Plunger
12 Quill Auto Feed Lever
13 Micrometer Depth Stop
14 Quill Lock
15 Quill Manual Feed Handle
Specifications
Table Length 54"
Table Depth 10"
Overall Width (A) 107"
X axis travel 36"
Y axis travel 15"
Z axis (knee) travel 16.9"
Spindle nose to table surface (min) 2"
(max) 26"
Spindle centerline to Z ways (min) 5.5"
max 26"
Ram travel 20"
Quill travel 5"
Head Tilt Left/Right ±90º
Head Tilt Front/Back ("nod") ±45º
Turret Rotation 360º
approximate weight 3000lbs
Accessories
The table is equipped with 16mm (5/8" compatible) T-slots.
The Mill has a three axis precision DRO; check this manual for details: Large_Mill_DRO_Manual.pdf
Tooling
This mill uses the same R8 collet system as the Rong Fu RF-45 Mill so any mill tooling we have will fit either machine. The bigger motor on the PM1054 means it can run bigger tools and/or work tougher materials than the RF-45. Pay attention to your speeds and feeds!
