Prusa MK3S+
The Prusa MK3S+ are good printers to produce small and medium sized objects using a single filament using many common filament types. The printer only uses one filament at a time, so if you want to print with multiple filaments, you will have to manually change filaments mid-print. If you need to print larger things or to use multiple filaments without manually changing them, use the Prusa XL. If you need to print in ABS, ASA, or other materials that print better enclosed, consider using the PolyPrinter 229.
Asmbly use: Use Skedda to reserve time on the specific printer.
Emergency Stop
Control Panel
Octoprint
Stopping or Pausing a print
If you stop or pause a print from Octoprint, it will not move the nozzle clear of your print. If you hope to resume, it is probably better to do this from the control panel.
Filament
Print Bed Sheet
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
If you are having trouble with getting your first layer to stick properly try one of these:
- Wash the sheet with Dish Soap at the coffee area sink. Make sure the sheet is completely dry before reinstalling it.
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook). You can also adjust it live while your first layer prints (Press the button while printing, selectLive adjust Z). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Material below here is being edited, but is primarily of interest to people maintaining the machines.
The printers are controllable over Octoprint, which you can use the web browser or an app to connect to while on the ASMBLY network. You cannot access these machines from home. Tasks such as preheating and filament changes can be done via the built-in panel on the front bottom of the printer. The Octoprint configuration is the standard OctoPi installation, consisting of the Raspberry Pi 3 or 4 being attached to the back of the printer frame, connected via USB to the printer and via Ethernet to the ASMBLY network (WiFi connection from the Pi to the network is currently unstable), with the OctoPi 1.0.0 (build 2023.10.09.151442) stable image installed on the Pi. In an attempt to keep the printers as easily serviced and maintained, we are trying to keep the installation as standard as possible. More documentation about OctoPi can be found here. Files for printing replacement Pi 3B and Pi 4B cases can be found at the page bottom.
Revo Hotend Upgrade
All three Prusa i3 mk3s+ printers have been upgraded with the E3D Revo hotend (from the stock E3D V6). They are all equipped with the 0.4mm abrasion-resistance ObXidian nozzles. Please do not change the size of the nozzles. We upgraded to the Revo to improve ease of maintenance and reliability of the printers, but do not currently have a system to support nozzle size changes.
Rebooting Procedure
In order to fully reboot the printer and the Octoprint server attached to it, power off the Pi at the back-upper-left of the printer by toggling it's inline power switch, and turn the printer off using the power switch on the power supply unit at the back of the printer. Then toggle the power supply unit switch back on, and then turn the Pi back on. The Octoprint page should be reachable in under one minute.
- User Manual
- Octoprint - Configuration and install
- Pi 4 Case with Prusa i3 Mounting
- Pi 3 Case with Prusa i3 Mounting
