Prusa MK3S+
Booking Policies
- Give back time that you don’t need. If you realize you’ll be late, change your booking to start when you’ll actually be ready to start. If your print ends early, end your booking booking in Skedda.
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[1]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened.
Emergency Stop
Control Panel
Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Nozzles / Hotend
- User Manual
- PrusaSlicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, selectLive adjust Z). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Other
Regular Maintenance
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
- Run through the
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook) - If you have trouble calibrating Z using just the First Layer Calibration, or you want to check the calibration, these models have been useful. They may already be on the printer in a directory named Calibration. If not, create that directory and/or add these files.
- If you have to set the Z further out than -2.000mm, the Z sensor probably needs to be adjusted. See 6.3.10.2 of the handbook
- The proper height for the sensor is about a zip tie's thickness
- If you move the Z sensor, do a Z Calibration, then calibrate the first layer again. You'll need to do this for all three sheet types, Textured, Satin, and Smooth.
