Prusa XL
Revision as of 20:38, 12 November 2024 by Mdixon4913 (talk | contribs) (minor changes)
192.168.1.144
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Unknown
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Network Address http://192.168.1.144/
Apollo, Hermes, and Sunwukong
All three printers
The Prusa XL is a good printer to produce small, medium, and large sized objects using up to 4 filaments. It supports many common filament types.
This printer have been equipped with abrasion-resistant nozzle ONLY on nozzle 1 ObXidian nozzles. This means that filaments that include additives like glow-in-the-dark (strontium aluminate), carbon fiber, glass fiber, wood, or metal are acceptable to use with this nozzle.
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Please contact a steward should a firmware upgrade message appear, or ignore the message if none are present.
Filament
Print Bed Sheet
Calibrated for Smooth1
There is a chart on the enclosure that lists which sheets are best for each kind of filament, or check Section 6.1 of the [2]
Nozzles / Hotend
Nozzle 1 is equipped with the 0.4mm abrasion-resistance ObXidian nozzles. Please do not change the nozzles.
yo.asmbly.org
Places to buy filament:
  4. Adjust the Z calibration. You can do this by going through the Calibration > First Layer Calibration process on the control panel (Section 3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, select Live adjust Z ). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted.
  5. Contact a steward
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
If the printer is printing too far away or too close to the bed for the first layer, the Z probably needs to be fine tuned. Try this:
  2. Run through the Calibration > First Layer Calibration process on the control panel
    1. Calibration Network
    2. Calibration E
    1. The proper height for the sensor is about a zip tie's thickness
