Prusa XL
192.168.1.144
The Prusa XL is a good printer to produce small, medium, and large sized objects using up to 4 filaments. It supports many common filament types.
This printer have been equipped with abrasion-resistant nozzle ONLY on nozzle 1 ObXidian nozzles. This means that filaments that include additives like glow-in-the-dark (strontium aluminate), carbon fiber, glass fiber, wood, or metal are acceptable to use with this nozzle.
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Please contact a steward should a firmware upgrade message appear, or ignore the message if none are present.
Filament
Print Bed Sheet
There is a chart on the enclosure that lists which sheets are best for each kind of filament, or check Section 6.1 of the [2]
Nozzles / Hotend
Nozzle 1 is equipped with the 0.4mm abrasion-resistance ObXidian nozzles. Please do not change the nozzles.
- [3]
- PrusaSlicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
Calibration > First Layer Calibrationprocess on the control panel (Section 3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, selectLive adjust Z). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
If the printer is printing too far away or too close to the bed for the first layer, the Z probably needs to be fine tuned. Try this:
- Run through the
Calibration > First Layer Calibrationprocess on the control panel - If you have trouble calibrating Z using just the First Layer Calibration, or you want to check the calibration, these models have been useful. They may already be on the printer in a directory named Calibration. If not, create that directory and/or add these files.
- If you have to set the Z further out than -2.000mm, the Z sensor probably needs to be adjusted. See 6.3.10.2 of the handbook
- The proper height for the sensor is about a zip tie's thickness
- If you move the Z sensor, do a Z Calibration, then calibrate the first layer again. You'll need to do this for all three sheet types, Textured, Satin, and Smooth.
