Prusa XL
Revision as of 17:14, 27 November 2024 by Valerie (talk | contribs) (Formatting)
192.168.1.144
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Unknown
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Network Address http://192.168.1.144/
Apollo, Hermes, and Sunwukong
All three printers
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  4. Contact a steward
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
