Prusa MK3S+
Booking Policies
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[1]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened.
Emergency Stop
Control Panel
Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Asmbly stewards will prioritize keeping the Prusa Satin sheets calibrated. You are welcome to use other sheets, but other sheets have different thicknesses, and you are responsible for calibrating the Z for your chosen sheets. To do this:
- Remove the Satin sheet from the printer
- Put your chosen sheet on the printer
- In the menus, select your chosen sheet. Use SMOOTH1 for the Prusa Smooth sheet, TEXTURED1 for the Prusa Textured sheet, and CUSTOM1 for other sheets
- Calibrate Z for your sheet
- Double check that you have the correct sheet selected. Please don't change the SATIN1 calibration if a different sheet is on the bed
- Use the First Layer Calibration tool in the printer's menus to run a quick calibration
- OR Calibrate the Z live using the Live Adjust Z menu item. You should find two gcode files on each of the SD cards for the printers named calibration_E and calibration_network which are single-layer prints designed to help you dial in the setting, but you can also do this during the first layer of your own print if first layer quality is not critical.
- If you find that you need to calibrate the Z beyond -2.000mm, please file a problem report. This indicates that the Z sensor needs to be adjusted.
To switch back to the Satin sheet:
- Remove the other sheet from the printer
- Put a Satin sheet on the printer
- In the menus, select SATIN1. This setting should be properly calibrated.
- If you get bad first layers (see First Layer Calibration to see what that looks like), follow the calibration instructions above or file a Problem Report
You will find various sheets in the top drawer of the black cabinet to the right of the enclosure for the Prusa printers:
- Textured Powder-coated Steel Sheet
- Satin Powder-coated Steel Sheet
- Smooth PEI Steel Sheet
- TheKKIINNGG Textured Sheet
Nozzles / Hotend
- User Manual
- PrusaSlicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, selectLive adjust Z). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Other
Regular Maintenance
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
- Run through the
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook) - If you have trouble calibrating Z using just the First Layer Calibration, or you want to check the calibration, these models have been useful. They may already be on the printer in a directory named Calibration. If not, create that directory and/or add these files.
- If you have to set the Z further out than -2.000mm, the Z sensor probably needs to be adjusted. See 6.3.10.2 of the handbook
- The proper height for the sensor is about a zip tie's thickness
- If you move the Z sensor, do a Z Calibration, then calibrate the first layer again. You'll need to do this for all three sheet types, Textured, Satin, and Smooth.
