BambuLab P1S
Members must complete the BambuLab P1S: Techniques Class before using this tool
Asmbly has one Bambulab P1s 3D Printer and one Automatic Material System (AMS). Located in the in the Multi-Purpose Room, these in the far corner to the room between the Prusa printers and resin printers. The P1S is named Poseidon.
Booking Policies
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[3]] to let us know that this happened.
If you need to print in ABS, ASA, or other materials that print better enclosed, please make sure to preheat the bed with the door closed for a minimum of 30 minutes at 60C.
Many types of 1.75mm filament will work with this printer. Please note that when using cardboard spools in the AMS, members MUST place a printed spool ring over the spool edge to avoid cardboard dust buildup inside the AMS.
This printers is not currently equipped with an abrasion-resistant nozzle. This means that filaments that include additives like glow-in-the-dark (strontium aluminate), carbon fiber, glass fiber, wood, or metal cannot be used with this machine.
If using a micro SD card to start a print, one is available for use and is always inserted into the P1S. However, if you find yourself printing from micro SD frequently, consider bringing your own.
Asmbly currently only provides a textured PEI printing sheet. Asmbly also provides cleaners for the sheet: Isopropyl Alcohol (usually in a squeeze bottle with the printer tools) and Dish Soap (in the coffee area just outside of the multi-purpose room.
Emergency Stop
If you see or hear something going terribly wrong with the printer, you can immediately stop it by shutting off the power switch located at the back bottom right of the machine. Examples of situations where you would want to do this: the nozzle is contacting the steel plate, the printer is trying to move the head beyond its rails.
Control Panel
The printer has a control panel that can be used to do things like preheating the machine, loading and unloading filament, pausing/stopping a print, and starting a print from an SD card.
Stopping or Pausing a print
You can stop a print from either the Devices menu in Bambu Slicer or the control panel. If you stop or pause a print from Bambu Slicer, it will not move the nozzle clear of your print. If you hope to resume, it is probably better to do this from the control panel.
Firmware Upgrade Warning
Ignore messages about a firmware upgrade warning..
Filament
Print Bed Sheet
- Check the waste chute after multimaterial prints and dispose of any purged filament
- [4]
- Bambu Slicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
- Wash the sheet with hot water and dish soap at the coffee area sink. Make sure the sheet is completely dry before reinstalling it.
- If printing in ASA or ABS, ensure that the chamber is preheated by heating the bed to 100C for a minimum of 30 minutes prior to starting a print.
- Contact a steward
- Use
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
If the printer is printing too far away or too close to the bed for the first layer (to see what these look like look at Section 6.3.9 of the handbook), try the following:
- Make sure the bed is seated properly and not warped.
- Make sure there is no debris on the nozzle tip when automatic calibration is being performed at the start of a print.
