Pearl
Revision as of 04:33, 5 November 2021 by Dannym (talk | contribs)
Pearl Setup
Turn on chiller, wait for 22C which will take under 5 min and the chiller will auto-regulate there. The chiller must be on to run the machine. It’s not harmful to start running earlier, but its power is going to increase as temp drops and it will be inconsistent Turn on the blower, currently with a switch on a power strip. There is no protection against not doing this, so don’t. Will make automatic pretty soon
Set Z for your stock
Pearl has a powered Z axis, but unlike Blue/Red, it is not controlled by driver settings. You lift or lower it to the correct location for your stock thickness and it will always run your job wherever the Z is. It will never move it automatically.
To move the Z, first press the "Z" button on the right once.
Locate the RAMP on the stick, just so you understand. This is the measurement point that will contact the BOTTOM LIP of the FRONT of the carriage at the perfect focal distance. It is sloped so it does not pinch or jam against the carriage if adjusted too high, but just tips away.
Use the Z UP/DOWN arrows to move the bed. Again, the "Z position" LCD display keeps getting changed somehow so just don't use it for now.
[[File:Pearl_Z_perfect.jpg]]This is perfect. The Z UP/DOWN button deals in 0.1" steps and that's good enough for most apps.
Press the "Z" button on the right to send the carriage home and return the stick to its hole.
Media size: DEFINED BY DRIVER
Orientation: PORTRAIT
Print Layers: ALL LAYERS
Placement: CENTER, right beside that enter X=0 Y=0
Scaling: DO NOT SCALE
“THE CATCH” of using Illustrator: every time you go to ULS’ “Setup” to change your power and print or save from there, Illustrator has been seen resetting ALL the above fields. So, reselect Portrait, Placement->Center, and change offsets back to zero after visiting the ULS setup window. If anyone knows how to keep Illustrator from reverting like this, that would be great.
ULS's Print Driver Menu
Laser Cutter Settings
