Pearl
Pearl Setup
Turn on chiller, wait for 22C (or whatever is labeled above the display) which will take under 5 min and the chiller will auto-regulate there. The chiller must be on to run the machine. It’s not harmful to start running earlier, but its power is going to increase as temp drops and it will be inconsistent Turn on the blower, currently with a switch on a power strip. There is no protection against not turning on the blower but that could damage stuff, so don’t. Will make automatic pretty soon
Set Z for your stock
To move the Z, first press the "Z" button on the right once.
Use the Z UP/DOWN arrows to move the bed. Again, the "Z position" LCD display keeps getting changed somehow so just don't use it for now.
Press the "Z" button on the right to send the carriage home and return the stick to its hole.
Media size: DEFINED BY DRIVER
Orientation: PORTRAIT
Print Layers: ALL LAYERS
Placement: CENTER, right beside that enter X=0 Y=0
Scaling: DO NOT SCALE
“THE CATCH” of using Illustrator: every time you go to ULS’ “Setup” to change your power and print or save from there, Illustrator has been seen resetting ALL the above fields. So, reselect Portrait, Placement->Center, and change offsets back to zero after visiting the ULS setup window. If anyone knows how to keep Illustrator from reverting like this, that would be great.
ULS's Print Driver Menu
Laser Cutter Settings
Running
Send job, press START. If you immediately hear TWO BEEPS, your job is EMPTY. Either the Orientation is wrong and it shifted all the content off the workspace, or you have VECTOR selected but the LINE WIDTH inside Illustrator, etc WAS NOT SET TO 0.001" WIDTH
Shutting Down
