BambuLab P1S
ClassWarningIcon.png Members must complete the BambuLab P1S: Techniques Class before using this tool
Asmbly has one Bambulab P1S 3D Printer and one Automatic Material System (AMS). Located in the in the Multi-Purpose Room's far corner between the Prusa printers and resin printers. The P1S is named Poseidon.
ASMBLY Bambulab P1S Printer
Poseidon
Status Active
Video Feed [TBD]
Manufacturer Bambulab
Model P1S + AMS
Nozzle Size 0.4mm
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 100C
Max Nozzle Temperature 300C
Max Print Speed 500mm/s
Extruder Type Direct
Manual [1]
Control Interface TBD
Network Address TBD
Booking Policies
  4. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[3]] to let us know that this happened.
Apollo, Hermes, and Sunwukong
All three printers
Many types of 1.75mm filament will work with this printer. Please note that when using cardboard spools in the AMS, members MUST place a printed spool ring over the spool edge to avoid cardboard dust buildup inside the AMS.
This printer is not currently equipped with an abrasion-resistant nozzle. This means that filaments with include additives such as glow-in-the-dark powder (strontium aluminate), carbon fiber, glass fiber, wood, or metal cannot be used with this machine.
Emergency Stop
Control Panel
To see the full list of screen controls, please visit [4]
Printing from the SD Card
Follow this guide: [5]
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
If you need help loading or unloading filament from the rear spool holder, please visit [6] or [7], respectively.
Print Bed Sheet
Calibrated for Smooth1
yo.asmbly.org
Places to buy filament:
  5. Contact a steward
  5. Use the brass brush in the tool caddy to wipe the heated nozzle
Other
Regular Maintenance
Follow this guide: [9]
Moving the printers
Rebooting Procedure
Z Problems
If the printer is printing too far away or too close to the bed for the first layer (to see what these look like look at Section 6.3.9 of the handbook), try the following:
Perform Auto Calibration
Navigate to the calibration option using the screen or Bambu Studio: [10]
Filament Sensor Inspection
If the following happens:
Printer sends the error message "Filament failed to send to the extruder", but there is filament in the tube above the toolhead.
When using the AMS, printer sends the message "Please pull the filament from the external spool", but there is no filament in the tube above the toolhead.
The printer sends the message "Please insert the filament into the port until it can no longer be pushed", but the filament has entered the extruder.
Please follow this guide: [11]
Hotend Clumping
In the event of hotend clumping, please follow this guide: [12]
Bed Not Heating
In the event that the bed does not heat up, please follow this guide: [13]
