Tethys
Revision as of 02:20, 12 April 2025 by MoonLitRose (talk | contribs) (Z height setting)
Unnamed SLA Printer
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
Resin Safety
  • Avoid breathing vapors.
Available Resin Materials
You may purchase resin here.
Chitu Box Slicer Setup
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
  8. Note from a Steward: Please be aware that at least some versions of CHITUBOX will attempt to auto correct an infrequent issue on build plate leveling by including in the slicing data a command to over shoot the the set zero that can lead to print fails by print over compression. After leveling, run a test print and then manually adjust the z height by the .1mm it is off by the calipers. As of 4/11/2025 the proper z hieght post leveling needs to be set at .9 mm above level sheet.
Post-Processing
If your print fails, particularly if some parts of the print don't adhere to the bed, it's likely you'll need to do a Resin Tank Cleanup. Please try to leave the tank debris-free for the next user.
3D Printers Space Team
Common Projects
