Pearl
Revision as of 08:58, 9 November 2021 by Dannym (talk | contribs)
Pearl is so similar to Blue that when Blue went down we're just steering trained Blue users over here with this guide. It cuts faster and cleaner than Blue, too.
Pearl Setup
Turn on chiller, wait for 22C (or whatever is labeled above the display) which will take under 5 min and the chiller will auto-regulate there. The chiller must be on to run the machine. It’s not harmful to start running earlier, but its power is going to increase as temp drops and it will be inconsistent
Turn on the blower, currently with a switch on a power strip. There is no protection against not turning on the blower but that could damage stuff, so don’t. Will make automatic pretty soon
Set the Machine Origin
(this might be due to the coin cell backup not working, it resets when powered down)
If this is not done, the work will be offset or shifted off the bed entirely and the laser may do weird things on the edges.
#1 Press the X-Y button to enter jog mode
#2 use the arrows to job to the top left of the bed, the LCD should read "POS 0.000x 0.000y" as the second line
#3 The LCD should have the cursor on "SET NEW ORIGIN", so hit "SELECT", ok the "are you sure?", display should now also read ORG 0x 0y as the first line, as shown above.
Set Z for your stock
#4 To move the Z, first press the "Z" button on the right once.
#5 Use the Z UP/DOWN arrows to move the bed. Again, the "Z position" LCD display keeps getting changed somehow so just don't use it for now. When done, just leave it, you don't need to set anything
#6 Press the "Z" button on the far right a second time to send the carriage home and return the stick to its hole.
The official ULS manual diagram
Media size: DEFINED BY DRIVER
Orientation: PORTRAIT
Print Layers: ALL LAYERS
Placement: CENTER, right beside that enter X=0 Y=0 (this seems to override the Placement, entering X=0 Y=0 might be what you really need)
Scaling: DO NOT SCALE
“THE CATCH” of using Illustrator: every time you go to ULS’ “Setup” to change your power and print or save from there, Illustrator has been seen resetting Orientation back to Landscape, it must be Portrait. So, reselect Portrait and recheck the above entries after visiting the ULS setup window. The Preview window does not seem to update correctly at this point but the laser will get it correctly.
If anyone knows how to keep Illustrator from reverting like this, that would be great.
ULS's Print Driver Menu
Laser Cutter Settings
Running
Send job, press START. If you immediately hear TWO BEEPS, your job is EMPTY. Either ORIGIN was not set to 0x 0y (step #1 above), the Orientation is wrong and it shifted all the content off the workspace, or you have VECTOR selected but the LINE WIDTH inside Illustrator, etc WAS NOT SET TO 0.001" WIDTH
Shutting Down
