Laguna Swift Vacuum CNC
Members must complete the Intro to CNC Routers Class before using this tool
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6 and #7.
- Take out bit. Remove/return nut and collet to toolbox.
- Turn off workholding vacuum, remove hold-downs, vacuum spoilboard, use chisel to flatten bumps
- Use vacuum/broom to clean around machine. Don’t use airgun to just blow it away!
- Sign out of Vcarve and the browser. Return shared USB drive to toolkit
- Shut down machine using procedure on laminated sheet
- Empty Dust Collector Barrel and Bag (if present)
- Clean DC Filter. (Big CNC - See sticker on side of DC).
- Return/organize/close CNC toolboxes
- Post cool pictures of your project on Discourse to encourage other members and build community
Filter Cleaning Steps
These are required after every use and should take no more than 30 seconds. Filter Cleaning Video TODO Relocate video to proper in-house server.
- Power On the Machine
- Close Inlet Blast Gate (White Circle)
- Push down Pulse Bar (Black Circle) 5 times. Wait 2-3 seconds between pulses.
- Open the inlet blast gate
