Laguna Swift Vacuum CNC
Revision as of 23:30, 20 February 2026 by Kenneth (talk | contribs)
Members must complete the Intro to CNC Routers Class before using this tool
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6 and #7.
  6. Empty Dust Collector Barrel and Bag (if present)
  7. Clean DC Filter. (Big CNC - See sticker on side of DC).
Filter Cleaning Steps
These are required after every use and should take no more than 30 seconds.
Filter Cleaning Video TODO Relocate video to proper in-house server.
  1. Power On the Machine
  2. Close Inlet Blast Gate (White Circle)
  3. Push down Pulse Bar (Black Circle) 5 times. Wait 2-3 seconds between pulses.
  4. Open the inlet blast gate
