Prusa XL
Revision as of 23:16, 17 July 2026 by Aneel (talk | contribs) (→Booking Policies)
http://xl-printer.asmbly.org
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Booking Policies
Because 3D Prints involve a lot of time when you don't need to be present, the policies are slightly different from the general booking policies.
  1. Time booked for 3D printing in Skedda does not count against your weekly usage hours, but time on the XL is limited to 48 hours per week. If you want to print a large object that will take longer, book the first 48 hours and email 3dprinters@asmbly.org to request more time. If it's available, we'll try to book it for you.
  2. It is fine for a print to continue while Asmbly is closed.
  3. You may book up to two 3D printers at a time.
  4. Book all of the time you need. Only print during time that you have booked. Don’t start prints that will go beyond your booked time. If your print has been paused or stopped because of a problem, don’t resume or restart it if it will go beyond your booked time. If time is available after your booked time, feel free to book more time to finish your print. If another member has already booked time that your print would need to use, and you contact them and get their approval, you may finish your print. However, if you do not manage to contact them, or if they do not agree to let you continue, then do not start, resume, or restart prints that would go into their time.
  5. Time you book is yours. If you arrive for your booked time and a print is ongoing, you may stop that print. If a print only has a few minutes remaining, it would be nice if you let it finish, but you are not under an obligation to do so.
  6. Give back time that you don’t need. If you realize you’ll be late, change your booking to start when you’ll actually be ready to start. If your print ends early, end your booking early in Skedda.
  7. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened.
Apollo, Hermes, and Sunwukong
All three printers
Print volume is 360mm x 360mm x 360mm (14.1" x 14.1" x 14.1")
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  4. Contact a steward
Trouble loading filament
If you are loading filament and it doesn't want to come out of the nozzle, here are some troubleshooting steps.
Make sure you have cut the end of the filament at a 45° angle, use the diagonal cutters if not
Check if your filament is loading into the tube that leads to the nozzle
  • Lift the catch that holds the idler door
  • Open the idler door
  • While you have the door open, look for any debris (usually ground up filament bits) on the idler gear. Use the air bulb (in the drawer of the wood table) to clean it out
  • Look at whether the filament is entering the tube at the bottom of the idler gear
Filament missing tube Filament entering tube
  • If the filament is missing the tube, try grabbing the end with a pair of pliers and manually inserting it into the tube. Close the door and the catch and try loading again
  • If the filament is aligned with with the tube, but nothing is coming out of the nozzle, probably some filament is stuck in the tube. Let's melt it out! Start by unloading your filament and then unscrew the end of the bowden tube.
  • Grab a piece of cleaner filament
  • Insert it into the extruder
  • Have the printer load filament at a temperature higher than what's in the tube. You can use a very high setting like PA if you don't know what the last filament was.
  • Hopefully, you should see something oozing out of the nozzle, and then eventually the translucent white of the cleaning filament. Use the "Purge More" command until the color is mostly translucent.
  • Unload the cleaning filament using the console and screw the bowden tube back in. Your filament should now load.
If these steps do not fix your problem, please open a problem report
There are other techniques for clearing problems like this (like using acupuncture needles, pressing the filament through with a tool, doing a cold pull, etc.). If you're comfortable doing those, feel free to try them, but the steps above usually resolve the problems we've seen on the XL.
Other
If you are unsure, feel free to contact a steward or fill out a problem report
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
