Big CNC
Max Z height is approx 7.5" from nut to spoilboard, but this does vary as spoilboard is added or removed. Note that the max usable stock height will typically need room for your bit to go on top of it
LinuxCNC control system
Checklist
Before I Start
- Mount the bit
- Unrack & Home
- Switch on Dust Collection
When I'm done
Tooling
Users must bring their own bits
Places to get bits in town
Sparktech in Round Rock has a very comprehensive range of carbide tooling appropriate for CNC routing http://www.sparktechinc.com/
Easiest shopping is through eBay, most inventory is listed. Select "local pickup", check out, drive to Sparktech
Sparktech's ebay store is CarbidePlus aka OliverToolCompany, username is DrillMan1
https://www.ebay.com/str/carbideplus?_trksid=p2047675.m3561.l2563
Woodcraft (limited range). Note that most hand routing bits are not appropriate for CNC
Dixie Tool Crib https://www.dixie-tool.com/
Online
Amazon and eBay, the obvious choices
Full ER20 collet system provided in Inch and Metric. However, they are communal and prone to wear which adds runout and reduces the hold, and you may wish to get your own collets so you know the condition. Collets are generally cheap, the Techniks brand is consistently higher quality for about $15-$20 collet. In practice the majority of carbide tooling is 1/8", 1/4", and 3/8", so that may be the only Techniks collets you need to get.
Videos explaining differences of upcut, downcut, and compression bits on wood
Video explaining superglue-and-tape holddown method
