Big CNC
Max Z height is approx 7.5" from nut to spoilboard, but this does vary as spoilboard is added or removed. Note that the max usable stock height will typically need room for your bit to go on top of it
LinuxCNC control system
Cuts wood, plywood, plastic, many other materials. It is also capable of cutting nonferrous sheet metal and billets (thick blocks of metal stock) with proper feedrates and compressed air nozzle. The compressed air nozzle will drive chips out of the cutting area so they are not re-cut by the bit and provide some cooling.
CANNOT CUT STEEL. Steel requires coolant which is not compatible with the MDF bed. Steel can create red-hot chips and sparks which can start a dust collector fire, a very dangerous situation.
Checklist
Before I Start
- Mount the bit
- Unrack & Home
- Switch on Dust Collection
When I'm done
Tooling
Users must bring their own bits. All CNC routing bits should be carbide, not HSS (High Speed Steel). HSS will not damage anything but the performance on wood, plywood, plastics, etc is poor.
An RCK-2249 surfacing/rabbeting bit is provided in the cabinet. This is an excellent choice for surfacing lumber slabs (live edge table) and pocketing. The 2 cutters on bottom of the bit plane the surface for a smooth face. It is 1-1/2" and uses two different types of carbide inserts which you will want to bring along with screws if you want to get the best quality cut. Larger diameter bits typically do not produce as good a finish, as any tram error (the spindle not being perfectly perpendicular to the surface) tilts the circle the bit makes which creates a slight scalloping of the surface and this requires more sanding to smooth out.
https://www.toolstoday.com/v-11847-rc-2249.html
The Diamond-Like Carbon inserts RCK-70-DLC and AMA-12-DLC are the best choice for surfacing lumber. This bit CANNOT PLUNGE it must approach the work from the side.
Places to get bits in town
Sparktech in Round Rock has a very comprehensive range of carbide tooling appropriate for CNC routing http://www.sparktechinc.com/
Easiest shopping is through eBay, most inventory is listed. Select "local pickup", check out, drive to Sparktech
- Sparktech's ebay store is CarbidePlus aka OliverToolCompany, username is DrillMan1 https://www.ebay.com/str/carbideplus?_trksid=p2047675.m3561.l2563
- Woodcraft (limited range). Note that most hand routing bits are not appropriate for CNC
- Dixie Tool Crib https://www.dixie-tool.com/
Online
- Amazon
- eBay
- https://www.toolstoday.com/
Full ER20 collet system provided in Inch and Metric. However, they are communal and prone to wear which adds runout and reduces the hold, and you may wish to get your own collets so you know the condition. Collets are generally cheap, the Techniks brand is consistently higher quality for about $15-$20 collet. In practice the majority of carbide tooling is 1/8", 1/4", and 3/8", so that may be the only Techniks collets you need to get. The ER20 nut is provided and generally does not have wear issues so it is not necessary to bring your own.
Videos explaining differences of upcut, downcut, and compression bits on wood.
Those are the 3 most basic types. There are many other types
- straight mill
- ball mill
- taper mill
- v-carver
- surfacing bits.
Within a type, there are variations in:
- flute count
- flute geometry
- flue length/diameter
- shank length/diameter
- coatings (DLC, Spektra) reduce friction, cut slightly cooler, and last longer
- Some bits have replaceable carbide insert cutting edges.
Video explaining superglue-and-tape holddown method
Conventional drill bits can be chucked in the ER20 system. Please use the tightest collet available, which may mean selecting a metric. Any slippage between collet and tool will generally damage the collet.
