BambuLab P1S
Members must complete the BambuLab P1S: Techniques Class before using this tool
Asmbly has one Bambulab P1s 3D Printer and one Automatic Material System (AMS). Located in the in the Multi-Purpose Room, these in the far corner to the room between the Prusa printers and resin printers. The P1S is named Poseidon.
Booking Policies
- Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[3]] to let us know that this happened.
The Bambulab P1S is a good printer to produce small and medium sized objects using up to 4 filaments with the AMS using many common filament types. The filaments can be mapped to the model using Bambu Slicer, Bambulab's proprietary slicer software.
If you need to print in ABS, ASA, or other materials that print better enclosed, please make sure to preheat the bed with the door closed for a minimum of 30 minutes at 60C.
Many types of 1.75mm filament will work with this printer. Please note that when using cardboard spools in the AMS, members MUST place a printed spool ring over the spool edge to avoid cardboard dust buildup inside the AMS.
This printers is not currently equipped with an abrasion-resistant nozzle. This means that filaments that include additives like glow-in-the-dark (strontium aluminate), carbon fiber, glass fiber, wood, or metal cannot be used with this machine.
If using a micro SD card to start a print, one is available for use and is always inserted into the P1S. However, if you find yourself printing from micro SD frequently, consider bringing your own.
Asmbly currently only provides a textured PEI printing sheet. Asmbly also provides cleaners for the sheet: Isopropyl Alcohol (usually in a squeeze bottle with the printer tools) and Dish Soap (in the coffee area just outside of the multi-purpose room.
Emergency Stop
If you see or hear something going terribly wrong with the printer, you can immediately stop it by shutting off the power switch located at the back bottom right of the machine. Examples of situations where you would want to do this: the nozzle is contacting the steel plate, the printer is trying to move the head beyond its rails.
Control Panel
The printer has a control panel that can be used to do things like preheating the machine, loading and unloading filament, pausing/stopping a print, and starting a print from an SD card.
Stopping or Pausing a print
You can stop a print from either the Devices menu in Bambu Slicer or the control panel. If you stop or pause a print from Bambu Slicer, it will not move the nozzle clear of your print. If you hope to resume, it is probably better to do this from the control panel.
Firmware Upgrade Warning
Ignore messages about a firmware upgrade warning..
Filament
Print Bed Sheet
- [4]
- Bambu Slicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, selectLive adjust Z). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Other
Regular Maintenance
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
- Run through the
Calibration > First Layer Calibrationprocess on the control panel (Section 6.3.9 of the handbook) - If you have trouble calibrating Z using just the First Layer Calibration, or you want to check the calibration, these models have been useful. They may already be on the printer in a directory named Calibration. If not, create that directory and/or add these files.
- If you have to set the Z further out than -2.000mm, the Z sensor probably needs to be adjusted. See 6.3.10.2 of the handbook
- The proper height for the sensor is about a zip tie's thickness
- If you move the Z sensor, do a Z Calibration, then calibrate the first layer again. You'll need to do this for all three sheet types, Textured, Satin, and Smooth.
