Pearl
Using Pearl Setup: Turn on chiller, wait for 22C which will take under 5 min and the chiller will auto-regulate there. The chiller must be on to run the machine. It’s not harmful to start running earlier, but its power is going to increase as temp drops and it will be inconsistent Turn on the blower, currently with a switch on a power strip. There is no protection against not doing this, so don’t. Will make automatic pretty soon
Pearl has a powered Z axis, but unlike Blue/Red, it is not controlled by driver settings. You lift or lower it to the correct location for your stock thickness and it will always run your job wherever the Z is. It will never move it automatically.
The Z is moved by panel buttons using the Z height shown on the panel's LCD. However, for some reason the Z height and/or focus keeps being incorrectly calibrated, we don't know why (possible user error), so we are NOT using this method until further notice. You need to use the stick.
To move the Z, press the "Z" button on the right:
Locate the RAMP on the stick, just so you understand. This is the measurement point that will contact the BOTTOM LIP of the FRONT of the carriage at the perfect focal distance. It is sloped so it does not pinch or jam against the carriage if adjusted too high, but just tips away.
Place the focus stick ON TOP OF YOUR STOCK LOADED IN THE BED, against the FRONT of the carriage. This is shown LOW, you need to Z UP:
Use the Z UP/DOWN arrows to move the bed. Again, the "Z position" LCD display keeps getting changed somehow so just don't use it for now.
Media size: DEFINED BY DRIVER
Orientation: PORTRAIT
Print Layers: ALL LAYERS
Placement: CENTER, right beside that enter X=0 Y=0
Scaling: DO NOT SCALE
“THE CATCH” of using Illustrator: every time you go to ULS’ “Setup” to change your power and print or save from there, Illustrator has been seen resetting ALL the above fields. So, reselect Portrait, Placement->Center, and change offsets back to zero after visiting the ULS setup window. If anyone knows how to keep Illustrator from reverting like this, that would be great.
When you do hit SETUP, you see the familiar ULS print driver settings:
The difference is there's no entry for Z, because it just runs wherever you left it after adjusting with the stick. PPI is now relevant, as this laser uses a pulse-mode source. 150 PPI for cutting and maybe 500 for rastering or fast engraving is a good suggested starting point.
Suggested settings 1/8" plywood 11% speed 150 PPI 0.2" plywood 8% speed 150 PPI
