Prusa XL
http://xl-printer.asmbly.org
username: maker
password: BcdhPrsUYS7EFz5
ASMBLY Prusa XL Printers
PrusaXL
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model XL
Nozzle Size 0.4mm
Nozzle Count 5
Filament Size 1.75mm
Max Bed Temperature 120C
Max Nozzle Temperature 290C
Max Print Speed 400mm/s
Extruder Type Direct
Manual [1]
Booking Policies
Time booked for 3D printing in Skedda does not count against your weekly Asmbly hours, but time on the XL is limited to 24 hours per week. If you want to print a large object that will take longer, book the first 24 hours and email 3dprinters@asmbly.org to request more time. If it's available, we'll try to book it for you. It is fine for a print to continue while Asmbly is closed.
  4. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[2]] to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email [[3]] to let us know that this happened.
Apollo, Hermes, and Sunwukong
All three printers
Emergency Stop
Control Panel
PrusaLink
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
There is a chart on the enclosure that lists which sheets are best for each kind of filament, or check Section 6.1 of the XL manual [4].
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  4. Contact a steward
Other
Regular Maintenance
Moving the printers
Rebooting Procedure
Z Problems
