Laguna Swift Vacuum CNC
Revision as of 23:19, 14 June 2025 by Rolo (talk | contribs)
Members must complete the Intro to CNC Routers Class before using this tool
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6 and #7.
  6. Empty Dust Collector Barrel and Bag (if present)
  7. Clean DC Filter. (Big CNC - See sticker on side of DC).
