Prusa MK3S+
Revision as of 21:17, 16 June 2025 by Aneel (talk | contribs) (→‎Z Problems: Added pictures)
Apollo
Status Active
Video Feed Video Feed
Manufacturer Prusa
Model i3 MK3S+ & Pi 3B
Nozzle Size 0.4mm
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 122C
Max Nozzle Temperature 295C
Max Print Speed 100mm/s
Extruder Type Direct
Manual MK3S+ Handbook
Hermes
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 4B
Nozzle Size 0.4mm
Nozzle Count 1
Sunwukong
Status Active
Manufacturer Prusa
Nozzle Size 0.4mm
Nozzle Count 1
Booking Policies
Time booked for 3D printing in Skedda does not count against your weekly Asmbly hours. It is fine for a print to continue while Asmbly is closed. You may book up to two 3D printers at a time.
  4. Don’t let time go to waste. There is a two hour grace period at the beginning of a booking. If the booker is not present after two hours and the printer is still idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened. There is a 30 minute grace period after the completion of a print. If the booker is not present and the printer is idle, another member may claim the remainder of the time on a first-come, first-served basis. Email 3dprinters@asmbly.org to let us know that this happened.
Apollo, Hermes, and Sunwukong
All three printers
Emergency Stop
Control Panel
Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Asmbly stewards will prioritize keeping the Prusa Satin sheets calibrated. You are welcome to use other sheets, but other sheets have different thicknesses, and you are responsible for calibrating the Z for your chosen sheets. To do this:
  1. Remove the Satin sheet from the printer
  2. Put your chosen sheet on the printer
  3. In the menus, select your chosen sheet. Use SMOOTH1 for the Prusa Smooth sheet, TEXTURED1 for the Prusa Textured sheet, and CUSTOM1 for other sheets
  4. Calibrate Z for your sheet
    1. Double check that you have the correct sheet selected. Please don't change the SATIN1 calibration if a different sheet is on the bed
    2. Use the First Layer Calibration tool in the printer's menus to run a quick calibration
    3. OR Calibrate the Z live using the Live Adjust Z menu item. You should find two gcode files on each of the SD cards for the printers named calibration_E and calibration_network which are single-layer prints designed to help you dial in the setting, but you can also do this during the first layer of your own print if first layer quality is not critical.
    4. If you find that you need to calibrate the Z beyond -2.000mm, please file a problem report. This indicates that the Z sensor needs to be adjusted.
To switch back to the Satin sheet:
  1. Remove the other sheet from the printer
  2. Put a Satin sheet on the printer
  3. In the menus, select SATIN1. This setting should be properly calibrated.
  4. If you get bad first layers (see First Layer Calibration to see what that looks like), follow the calibration instructions above or file a Problem Report
You will find various sheets in the top drawer of the black cabinet to the right of the enclosure for the Prusa printers:
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  5. Contact a steward
Other
Regular Maintenance
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
Note: z-height adjustments are given with negative numbers, so -1.500 is "lower" than -1.200.
Your print's first layer should be smooth and even. If it's not, the Z probably needs to be fine tuned. Try this:
  2. Run through the Calibration > First Layer Calibration process on the control panel (Section 6.3.9 of the handbook)
    1. Calibration Network
    2. Calibration E
    1. The proper height for the sensor is about a zip tie's thickness
