Laguna iQ CNC
Revision as of 22:28, 14 December 2025 by Aneel (talk | contribs)
Asmbly recently acquired a Laguna IQ Desktop CNC. It uses the same software and workflow as the Laguna Swift Vacuum CNC, but with a 24" x 36" work surface using conventional hold-downs.
ClassWarningIcon.png Members must complete the Intro to CNC Routers Class before using this tool
The Laguna IQ CNC has a 3hp continuous-duty liquid-cooled spindle. It can make any cut the big CNC can make.
This should serve as a reference on how to properly finish up your CNC session. Please pay special attention to #6.
  6. Empty DC - both the separator and the bag
  7. Take large scraps to dumpster
